[ View Full Version Of This Page ]
2000 SS with 122K miles
All Forums » Engine & Internal » 2000 SS with 122K miles
jamesgang
2/5/2007 4:48:25 PM
OK need some help here people.  I replaced one of my coils that the computer said was bad, I also replaced Ign. module for that coil.  I still have the same problem.  When under easy acceleration everything is fine.  But when getting on the freeway or the engine shifting down to it's passing gear, I get up to 4500 rpms and the engine just dies and won't accelerate any more.  I can hear the engine knocking and the car actually starts slowing down.  If I let up on the gas the engine will shift up and I'll gain speed.  I've dropped $600 and haven't been able to fix it.  I don't want to spend anymore money unless I know what the hell is going on.  The diagnostic machine has said everytime that it's the coil/ign. pack because I'm getting 500+ misfires on that cylinder and my mileage has dropped from 26 to 19 mpg.
What is the deal????
rchurch
2/5/2007 5:27:21 PM
I'm no expert, but mine was doing that and it was the cat plugged up.
fever42
2/5/2007 6:48:18 PM
MINE WAS DOING CLOSE TO WHAT YOU SAID, MAF SENSOR NEEDED CLEANING, USE BRAKE CLEAN ONLY NOTHING ELSE
2000LS
2/5/2007 7:02:47 PM
i'd be thinking cat too
wiz kidd
2/6/2007 8:27:22 AM
i would definetely check the cat converter..thats what it sounds like to me
also, there's 3 coils on the car so did you change the right one???   did you change plugs and wires as well??
check air filter too...i know this wont cause that...but you should make sure its clean ...   its hard to tell without actually looking @ the car
jamesgang
2/7/2007 12:24:29 PM
When I did the coil, I also did the plugs and wires.
Took it to the shop and went for a ride with the tech.  TRANNY!!!!   Brought it back and he said the last time is was serviced it had 1-1.5 quart overfill.  He's going to flush it, refill and take it for a spin before we dig any deeper.  Cross your fingers that it's not any worse or I'll be over on the LS2 GTO site all the time after trading in the Monte.
jamesgang
2/8/2007 10:04:37 AM
Picked up the car from Midas.  My buddy had flushed the tranny and filled it to the correct level and still had the same problem.  Drove down the block to AAMCO and let them have it for the afternoon and waited for the call.  ring ring....Hello AMMCO, goodbye $2K.  So I'll get it back next Monday or Tuesday with a 3y/36K mile warrenty on my rebuilt tranny.  AAMCO was nice enough to pay for the rental car for me.
RocknSS04
2/17/2007 10:25:34 AM
I don't understand how a p0306 or whatever misfire code you get had anything to do with the tranny. Sounds more like the cat to me, also. I've replaced both on my '01 SS LE. Unless your tranny died totally, I'd be leary of a rebuild, which by the way, was $1,400 on my '01. My reverse gear exploded. Wouldn't move. Sounds like yours is going OK, just no top end.  Besides, Aamco? They make their money by rebuilding transmissions, whether they need it or not. Hope they are right!
It still sounds like a cat problem, with an ignition problem to boot. Probably a bad coil pack still. Maybe a wire. Platinum plugs last forever!
Let us know how your misfire problem is.
http://www.cardomain.com/ride/2319272
jamesgang
2/21/2007 3:49:16 PM
$3500 later, a new tranny, coil, and module.  AAMCO said the tranny was a mess inside and in the process of fixing and test driving it the new coil and module went out again.  They replaced both of them at no charge and almost 2 weeks later I might get my car back, tonight.  I went in Sat. to pick it up and it was doing the same thing so after I brought it right back I walked accross the street and test drove an 06 GTO.  If the Monte doesn't work out I know what I'll be driving next.
bilms01
2/21/2007 4:55:24 PM
quote:
ORIGINAL: RocknSS04
FWIW I have always replaced ALL the coils and module at the same time. Sometimes they can arc externally or cause a voltage spike into the primary side of the others and take them out also.
Check your fuel injectors, at full throttle acceleration the pulse rate has a rather short pulse width and to a sticking or degraded coil winding may seem like it has constant voltage applied to it. All of which in turn can and will damage the CAT. While the CAT can and will degrade over time my experience has told me that more often than not it is a victim of other fuel/ignition issues. Sounds like you might have a couple different problems.
Sounds like AAMCO hosed you pretty bad. Request the old parts and you will probably see one h*** of a tap dance. That's a lot of money to still have the same problem. I think I would have a rather one sided "discussion" with them about how much I had just spent for nothing.
RocknSS04
2/24/2007 7:47:41 PM
I still say cat & coils.
thatrealcreolenigg
2/25/2007 2:00:48 PM
mine was doing that and it was the cat... matter of fact it will keep gettin worst till it wont even run
jamesgang
2/28/2007 5:49:42 PM
Well Monday AAMCO put in a new fuel pump at no cost to me because they thought it was the problem.  Still not fixed.  So they drove it across the street to the GM dealership and paid for the engine diagnostics.  They said they think it's a sticky valve.  No results back from the test.  AAMCO is picking up the tab on that also.  I KBB the car before taking it in and it came out to around $5K.  Right now I'm $3.5K + into it.  I don't want to drop another two thousand dollars on this car when I could have traded it in on a 05 GTO.
I'll keep this thread updated to the results of their work.
2000LS
2/28/2007 7:15:07 PM
....sounds more like AAMCO is out about $3500
RocknSS04
2/28/2007 8:25:52 PM
Sticky valve?   BULLS__T!!  Not on a 3.8! Not unless you have totally neglected it, and even then?
jamesgang
3/1/2007 5:00:25 PM
Well got it back today and I owe everyone on here an apology.  Chevy probed the cat. and said that was the problem.  The catalytic converter was shot.  A lot of people on here said that is what I should have looked for.  Unfortunatly the cat being clogged is what over worked the tranny and one thing broke the other.  So I have a new tranny and cat., $4100 later.
Now listen to this.  I take my car off the lot, get on it to check out their work and now I have a huge exhaust leak.  I took it back to AAMCO and their going to ask the Chevy tech about it.  I can't win with this thing.
04 Intimidator
3/15/2007 12:56:04 AM
How many miles are on your monte?  GM covers Catalytic Converters up to 100,000 miles.
SolaraSlayer
3/15/2007 7:02:53 PM
quote:
ORIGINAL: RocknSS04
Not true.  Like I put up on another thread.  I burnt 2 valve seats with a plugged cat on 2 different engines.  The backpressure caused the valves to over heat.
I hope your valves & seats are okay.  I went through 2 engines because of a plugged cat.
SolaraSlayer
3/15/2007 7:05:01 PM
quote:
ORIGINAL: 04 Intimidator
I think the thread started with "122k miles."
Return to the Monte Carlo Forum home page - Archive Home
