weird tail light problem
Old 12-04-2010, 06:50 PM
Zmonte34's Avatar
Default weird tail light problem
When i put the turn signal on when i have the brakes applied i lose all brake lights but the turn signal is still on has this happened to anyone before and if so how the F do i fix it i cant fiqure it out!!
Old 12-05-2010, 09:56 AM
Zmonte34's Avatar
So i looked at it some more this morning and i think its the turn signal switch, when u hold it on the brakes work fine but when you click it down the brake light goes out so i thing its in the arm but im still not sure.
Old 12-05-2010, 10:41 AM
i would check all the fuses and the wiring behind the tails to make sure nothing is wrong with it
Old 12-05-2010, 03:03 PM
please read the following from a previous thread, I believe this is the best answer for your issue
Skylark65(Ryan) posted it about having the same issues, good luck and I'm sure if he stops by the forum he will be able to give you more specific answers?
actually, your kinda lucky if your airbag is outta the way in the steering wheel, the wheel needs to be removed with a puller to acess the turn signal swich... i had to replace mine 'caus of the whole "no brakelights" thing ( the police love THAT excuse, lol) the swich can run kinda expencive, but i got mine at advanced auto for about $65 if i remember, and it has the provisions for the steering wheel radio butons. once the wheel & airbag are out of the way, the job can be done in about 2 hours if ya take your time & reuse your signal lever. but other than that its fairly straightforward
Old 12-06-2010, 01:32 AM
nitehawkjcb's Avatar
I gotta go with a bad multifuncton/turn signal switch too
YeahDoggie
08-03-2013 05:54 PM
98MonteZ34
06-27-2011 11:31 PM
SpinEm_90
01-11-2011 10:49 PM
kaligoman
04-14-2009 04:44 PM
mavrickf1613
04-15-2008 12:01 PM
Quick Reply: weird tail light problem
