Guide: Replace Gear Shift Knob
Old 10-07-2005, 03:44 PM
ralphtrent's Avatar
Default Replace Gear Shift ****
I finally did it. Here is how.
I replaced the stock shifter **** with an Autotecnica APA 100-510 (Carbon fiber like with leather)
Tools
* 2 pairs of needle nose plyers (one is ok if you have a pair of rounded nose plyers see below)
* 1 pair of rounded tipped need nose plyers (if you do not have two pair of needle nose plyers)
* an extra set of hands is helpful but not required
Steps
* Pull down the leather wrapping that is directly below the shifter. This wrapper is called the bottie.
* The **** is attached to the shaft by a 'U' clip the 'bottom' part of the 'U' clip can be seen slight sticking out the front (toward the dash) of the ****
In the rear of the ****, you will see two small slots, this is 'top' of the 'U'. With a pair of need nose plyers squize the sides and press in.
* The 'top' part of the 'U' should start to pop out. With an other pair of needle nose plyers or round tipped needle nose plyers, pull on the 'U', this is where the other set of hands can come in to play. If needed to get more grip, push the 'top' part of the 'U' in a little more.
* When the 'U' is out all the way, pull up on the ****. That is it. I would recommend that you put the clip back in the **** where it came from, so you do not lose it.
Old 10-07-2005, 04:19 PM
Default RE: Replace Gear Shift ****
I'd like to see some pics.... Nice write up!!!!
Old 10-07-2005, 05:14 PM
oooo oooo oooo me two want to see pic's too !!!!!!
i have thought of doing somethin like this once. then i looked at it and thought it might not be as much fun LOL
Also have see where folks have shortend the stock one so that it was not in the way all the time
Old 10-07-2005, 06:31 PM
ralphtrent's Avatar
OK i will work on pics and post them tomorrow, It is supposed to ran here in jersey so I will see what I can do.
Old 10-07-2005, 06:54 PM
thanks for the pics i will be looking for them
As far as the rain you can have it and keep it there. Other wise in about a week i will see it here.
Old 01-24-2010, 01:08 PM
Taz is offline
Bumping thread to first page.
Old 01-24-2010, 01:21 PM
I am rather unclear on the Gen? and where did u get the shifter?
Yes lets c some pics of it installed please
and the rain if it will melt the snow and/or get the salt off the road send it here lol. I prefur rain over snow anyday
Old 01-24-2010, 01:33 PM
Taz is offline
Hi Jonny.
Ralph retired from the forum years ago.
I'm pretty sure he was referring to the 6th gens. But I think it may be the same, if not similar, for the 5th and 7th gens too.
Why did I bump the thread? I'm going through the threads in this section and placing them where they properly belong. Plus many How To's were damaged by our server problem in 2008. I'm attempting to repair them or delete them if they can't be salvaged.
oamos
24
10-12-2013 10:30 PM
magnnuss_75
01-14-2009 10:40 PM
applejuice
07-12-2008 10:22 AM
Sir Monte
06-11-2008 02:45 PM
ralphtrent
08-24-2005 12:25 PM
Quick Reply: Guide: Replace Gear Shift Knob
